Help!! Info?
    Help!! Info?
    I'm having a problem with my front left wheel, when im runnin slowly my car starts to tremble a lil bit and move side to side, im not sure if its the wheel itself that has a problem or the wheel support. When im at a high speed, my car starts to tremble even more, and my steering wheel is not straight even though the wheels are, and the steering wheel starts to shake aswell. I want help, or some tips of what i can do to fix this, because i've tried a few things but it still has the problem.
    Thank You
    3L BLaCkOuT
    ~3L BLaCkOuT~
    have you
    tried rear wheel alignment first, if not fixed, than could be a tie rod that needs replacement....maybe ?
      Get an alignment and get your wheels balanced then come back and tell us if it still does it.
        allignment is off, you might have a bent wheel my friend had a subaru that he jumped like 7 feet in the air hah and the same thing happened to him, not that you have been jumping your car but just a possibility
        "Mind Over Matter, If I Don't Mind, It Doesn't Matter"
        http://www.cardomain.com/ride/2049267
