If the radiator doesnt work?
    If the radiator doesnt work would it make the engine rev up and down(low) I cant figure it out because the radiator doesnt work due to a front end collision and i was moving it and it was reving up and down not in gear tho? hope theres no other problem Thank you
    also does anyone have any advice to fix rust on rear quarter panel?
    THANK YOU IN ADVANCE!!
    If you have low coolant level yea it would do that. Does the radiator look damaged...If it doesnt take a heat gun or somethin of that nature and look for hot spots. But if you got in a front end collision I would replace that and check your coolant level. Plus I would give your IACV a check.
      ok
      Kool thank you for getting back to me, i figured as much thanks
      be safe
