leaks
    leaks
    Does anyone else have a leaky trunk problem? If you do is there a simple way to fix it? Thanks.
    change the weatherstripping around the trunk... cheap easy fix
      since i felt generous... hes the DIY to fix it... http://www.cb7tuner.com/vbb/showthre...ighlight=leaky
        I already changed the weather striping, it's leaking from the window seal is there something I can buy to seal it up?
          Ha Ha Ha Ha Ha. Man, if only you knew. This and Rust in the rear quarter panel are like the most common problems of CB7's.
          Check out the DIY forum and search for trunk and leak..... there are a couple different fixes. Good luck.
          Why? Because... Life Happens @ 4500 RPM
          Frost White CB7 Member 31
            Between the time I was watching TV and posting my answer this guy had the link. Nice.
              That is my exact problem, this is the fastest problem I have ever solved, thanks.
