Need help, engine problem!!
    I just buy a 1990 honda accord lx and the engine idle rough and want to die. I buy new exhaust system with new header and catalytic. then i change out the spark plugs, wires and cap and with new oil. The car still want to idle rough and want to die. the engine light also come up. Does anyone know how to fix this problem?
    Well you need to diagnose and pull the codes and see what the ecu is trying to tell you . Then atleast that will narrow the problem down. Oull the codes and get back to us .
      Yessir as Mr sparkle said just get the code and we can work from there. Could be your o2 sensor or you need to clean out your EGR Ports.
        http://www.cb7tuner.com/vbb/showthre...=resetting+ECU
        Here's the link for diagnosing CEL problems.
        Just follow it and figure it out.
        and just a suggestion, learn to use the search option.
        (RIP)1993 LX Sedan
        Frost White Crew Member #36
        JDM Beating Stick Owner #1
        My (old) Ride
          I went and have it check. It seem that i had no compression on cyl#3
