CB7 1993 2.2l random crank no start
    Hello all,
    I need technical help with my CB7 please, it's a 1993 cb7 2.2 l.
    The problem is that it cranks but doesn't start, in the mornings it often doesn't start at all, but when I wait some minutes it sometimes starts. Also when I drive the car it drives and revs very normally and never stalls during the drive, just when I for example drive to the gas station or anywhere, and stop the motor it refuses to start again, only after some minutes of waiting, and sometimes it doesn't start at all in that situation.
    Does anyone know about such a problem? I had to one get the car be towed away to the garage, and the towing man tried his emergency tricks, he checked the battery and forspark and fuel but he couldn't make it start so it was sent to the garage.
    Would be cool if someone could help me!
    Main relay is likely your issue. The solder joints get old and are easily affected by temperature etc.
      Sorry for the late reply, we checked the main relay and it did have tiny cracks in two solder points on the circuit board and we soldered them, but the next day the car didn't start again so we ordered a new cheap distributor(not original Honda) because we need the car running again asap, and now the car works again, fingers crossed. I hope the car runs well now, if not I will be back Thanks again! I'm happy to have found this forum!
        Awesome. Ya only a few things that will cause these start/ no-start conditions. Dist/ignitor, main relay, ....fuel pump (relay). Weird
        too because it's random.
