i can’t understand where this sway bar goes as i’m looking under the cad and there isn’t even one there do i have to modify the subframe becuase there’s no holes to bolt it in and no mounting points on the oem coil overs. The car is a fully stock 92 LX. need help asap please
St suspensions rear anti roll sway bar install help
i have drum brakes in the back and i’m looking at the install instructions and they confuse me a lot
http://docs.stsuspensions.com/DGBT/51120.pdf
im stuck on number 4 and i don’t understand what it’s saying to do
Sounds like it would be close to this install - https://www.cb7tuner.com/vbb5/forum/...ay-bar-install
Also #4 just talks about the 17mm bolts that hold the OEM rear sway bar on, which you don't have. So you either have the OEM setup and this is a plug and play or non-OEM and you're doing what the link is i posted.
- 1 like
Originally posted by Raf99 View PostOnly the EXR in Canada and the SE? In the USA had the holes/tabs for the sway bar. Same cars that came with rear disc brakes. (Don't quote me...but I think that's what you are referring to).
Originally posted by UnicornHondaSE View PostWould love to see pics of the final result! My bro's is a '91 SE so I think it has a sway bar. Any idea on the size of OEM vs the ST?
Originally posted by UnicornHondaSE View PostAwesome! Thanks, the pics are fine, but it looks like the bar is touching the exhaust pipe. Probably only the angle of the photo
Thanks for the info too on bar width, that's a huge difference.
Have you noticed a significant improvement in cornering stability?
