93 Cluster Question
    93 Cluster Question
    I have a 93 LX 5-Speed no-ABS. I picked up a 93 Coupe 5-Speed EX Cluster that has the ABS Function on the Cluster. Can I run this Cluster and will the ABS Light in the Cluster illuminate or stay off? Thanks
    91 Accord LX 5-speed
    93 Accord LX 5-speed
    You might be the first to report on it. I expect it would stay off. Actually now I'm wondering if my cluster was from an EX. I'll check later.
    1991 Accord Lemons Race Car, "The Minnow" RIP
    1993 Accord Lemons Race Car, "SpaceEx Starship"
    Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
    Adj Upper Control Arms -3.0deg front, -2.0 deg rear
    M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
    Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
      Update. I went ahead and installed the Cluster, The ABS light does not come on, everything works. I will need to check the backlight and dimmer when it gets dark. This is my third time replacing a Cluster and it's a bear, the screw behind the lighter is hard to change with the lighter installed. I should have looked up how to remove the lighter.
        The lighter unscrews, as a unit, from the black bezel that holds it in place. It can be tough as there is no leverage if it is seized in place
          Thanks, I started to twist it then stopped thinking that I might break the wires.
