I know most ofthe people here have the f22 engine but my accord has the jdm h22,know my question is how to you do a egr bypass? I know I need a bock off plate but how do you do it?
how to do a egr bypass on a h22a
You need a block off plate and a chipped ECU. ANd there are quite a few people with h22A.
theres two 12mm nuts holding the EGR valve down, take those off and pull the valve off. youre going to want to cut a piece of metal to cover over the two holes, the round one and the square one. even a rectangular strip across the holes is fine, or you can cut one thats the same shape as the flange so it fits flush. use 888 super high temp copper silicone (any parts store) to make sure its sealed, then bolt the EGR valve back down on top of it, and youre done. leave the valve connected to everything, so the ECU thinks its tehre and working so you dont get a check engine light, but its really not doing anything.
heres what mine looks like, i made it with a dremel:
[img]http://www.****.com/www/93lx/EGR_blockoff.jpg[/img]
When it recirculates it distributes unequal flow back inside the IM to the combustion chambers making numbers 3/4 cylinders get a lotta carbon buildup. It was something like that since the EGR uses the number 4 cylinder exhaust to recirculate.
I might do this. I have one question. If the ecu still thinks the egr is working doesn't it still compensate but adjusting fuel for the egr it thinks is still going into the engine?
Is the right way just to pull it out and tell your chipped ecu not to look for it?Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
i have a block off plate on mine and i bolted the egr valve back and the valve is connected, but i still get the check engine light, wich is the egr (code 12).could
my valve be bad? what i seen is that they use the h22 connecter wich it has wht/blck, grn/wht, red/wht wires connected to wht/blck, grn/wht and yellow/wht wires coming out of the f22 wire harness, are those the right ones or
could some one let me know what the right egr wires from the f22 harness are
