Wondering if this ROH conversion with 282mm rotors will clear on stock 91' SE wheels. I believe they're 15x5.5 on the wheel dimensions. I need brakes pretty badly and figured I might as well get this conversion over with.
ROH clearance for 282mm rotors?
I can't speak specifically to the SE wheels, but my guess would be that they should. I have Prelude swirls on my car currently with that brake setup and I imagine that most of the other OEM wheels will clear. I will add though that I require a small front spacer on the Prelude wheels to clear. However, based on the specs, the offset on those is +50 while most of the OEM Accord wheels are +45, so you may not need the spacer as the one I use is literally just a 5MM spacer.
- 1 like
I'm not sure that's right. I did this same brake conversion on the racecar and the stock steelies that were on it when we bought it would no longer fit. I didn't try a spacer though. I just got rid of the steelies.==========================
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
Originally posted by ukemike View PostI'm not sure that's right. I did this same brake conversion on the racecar and the stock steelies that were on it when we bought it would no longer fit. I didn't try a spacer though. I just got rid of the steelies.
