i need speed cause i have none
    Accord has no accelaration all i hear is exuast but iam only going like 30 mph if i floor
    the pedal no power all you hear is a loud exuast the rpms going up really slow like i dont have any gas and it studders.
    some one said that the egr ports maybe clogged but the car revs fine while in idle
    and the hot wire in my car for the radio does not work and all the fuses are fine
    no power from that one wire like its a short
    changed distrubutor
    spark plugs
    wires
    fuel injectors
    fuel filter
    high flow cat
    NO matter how many times we downshift vtec is on our side.
    You have an automatic, huh?
    Gary A.K.A. Carter
    [sig killed by photobucket]
      no 5 speed its to hard to drive a automatic it hurts my brain
        if you have an f22a6 then it's most likely to be the egr ports. there only like 2 bucks to replace
          2$ to replace the egr canister? hmm, i'd think it'd be more than that, but what do i know. just clean them and you will love it. also, change all your fluids and clean the IACV and the TB while you are under there and taking stuff off.
