coolant Question
    coolant Question
    ok so this summer wut is the coolant suposed to b at? 20% or 30%. and the rest water. right?
    old accord
    http://www.cardomain.com/ride/2261780
    50/50. later.
    Avoiding dirt at all costs
      Originally posted by TypeG
      50/50. later.
      x2, you can get it mixed 50/50 in a bottle, so there is no guess as to what the final ratio will be. The water cools, the antifreeze is an anti-corrosive and a freeze inhibitor. Also, you should use distilled water in your cooling system.
      1992 Accord LX - SOLD
        Wtf Is Distilled Water?
        old accord
          You don't HAVE to use it, but some manuals reccomend it. Distilled water is water that has been boiled and then recondensed (that is, the water vapor is turned back into liquid water on a cold surface). People distill water in order to purify it. Dissolved contaminants like salts are left behind in the boiling process.
            oo so that means less corrosion on the radiator rite?
            old accord
              yup yup and like maroonaccord said it removes salt and other conatiments and it also takes out calcium in the water
                don't use well water, well water in collant systems=BAD
                  you can find distilled water at your local grocery store for like 75 cents a gallon. they also tell you to use that kind of water in car batteries back in the day.
                    getting it mixed is such a rip-off! you get the same amount for the same price, and you are only paying for half the antifreeze..you pay for water too, thats ridiculous. its not like its an exact science. a little bit off wont hurt your car.
