AC clutch wire
    AC clutch wire
    So my ac clutch wire, the black wire that looks almost like old knob and tube wire, somehow managed to get pinched and cut by my alternator tensioner bolt. The ac only works now when I manage to get the wire to stay, as one would imagine. But my question is, is there a way to dismantle the ac pump possibly while on the car, if not I'm just going to either try and solder or crimp connector it, would be that much easier if I could get better access to the wire inside the pump.
    Ya, you need inside the pump. Sucks bc you have AC and don't want to take the lines off. Assuming you have R134 in it I'd just take the AC off and do it right. Go get a refill.
      Im actually still on the r12, but if I can take it apart might as well do the swap to 134, good reasons for me to take it off the car and work on it. Thank you
