Spark Plug replacement and valve adjustment lead to stalling engine
    Hey yall, 91 accord here I won her at an auction and I decided to change her spark plugs when I took out the plugs they were drenched in oil so i took off the valve cover and replaced all the gaskets and since the valve cover was off i decided to do a valve adjustment following this procedure: https://www.cb7tuner.com/vbb5/forum/...lve-adjustment
    I also replaced the spark plug wires because the spark plug boots were oily. When i her back together and started her engine she idles really low and really rough and she vibrates a whole lot and if I hit her accelerator her engine just turns off unless I press it hard and shes backfiring off not to mention there is a whole lot of smog from the exhaust which was not there before. What can this be and what can I do to fix her? Oh and its worth a mention that I flushed her coolant before i did the spark plugs/ valves/ gasket.
