Rods Question?
    Rods Question?
    I have been looking into rods for my F22A1 bottom end. Are H23A and F22A1 rods the same? I was wondering because I was looking into getting some Crower's. I also was doing some research and heard people talking about crank and rod combinations that would increase displacement, could someone go into detail on these questions for me? Thanks alot!!!!
    youre right with the h23 rods fitting the f22, theyre the same pretty much.
    as far as cranks go, thats gona be a bitch.
      crank and rod combinations that increase displacement is called a stroker kit, but unfortunatly i cant find a place that sells one for the F22A1, because i would like one too, they give ya much more torque over a stock F22A1 because of the longer stroke
        he's prolly not talkin about stroker kits, but rather something along the lines of using an F20 crank in a F22 block or something along the likes of such...a frankenstein build..
          h23 and f22 rods are the same thats why honda gives them the same part number.
            You can also use the crank from the F23. The general rule is that as the stroke increases the rpms decrease and vice-versa.
              f23 crank has 55mm mains while the f22 blocks and 92-97 h22 blocks only have 50mm mains...
                that's not a problem for a machine shop.
                  nope but its also gonna be $250 or more to make it happen.
                    the f already has a pretty long stroke, putting in a h22 crank would destroke it and decrease the displacement. I would just get the crank zero blanced and polished and replace the bearings with oem parts, that is if your gonna tear down your motor
                    spin city
