I recenlty aquired a 92 honda accord. Today while driving, it began to overheat. When I pulled over, I cautiously removed the rad cap. There was no pressure. Also, the cooling fan is not kicking on. Any advice, ideas?
Overheating, fan not kicking on!
Originally posted by 86accordlxI recenlty aquired a 92 honda accord. Today while driving, it began to overheat. When I pulled over, I cautiously removed the rad cap. There was no pressure. Also, the cooling fan is not kicking on. Any advice, ideas?
EDIT: .. umm er .. first make sure the fan is plugged in properly .. just a thought ..
A Hui Hou !!!
Tomi
Jump the fan switch and see if they come on. Was there any fluid in the radiator? If there wasnt pressure test it for leaks. Yea and check your connections. Turn on your A/C and both fans should come on if one doesnt that means its bad.
lol might have been just a loose connection then. Main Relay would be fuel related Not bad though.
Originally posted by 86accordlxThanks. Managed to get the fan going. Hit the dash (drivers side) and fan came on. Just took it for a ride and the car is running fine! I suspect it could be the main relay. Not bad for a girl, eh!!
Sorry NAiL05 .. that wasn't directed at you ..
Seriously tho .. you just *hit* your dash ? Wow .. remind me never to piss you off ..
A Hui Hou !!!
Tomi
