i have this horrible squeak whenever i hit a bump and when i turn mostly when i turn though, but someone told me it was my tierod bushing, anyone have any ideas?
horrible squeak
Could be a balljoint or tie-rod end in need of some cleaning/greasing or replacement. But, it sounds to me like the bushings in the power steering rack are shot. I don't know if the units on these cars are rebuildable (most aren't), so it might require replacing the whole unit.
2¢
EDIT:
- Jack the front of the car up
- Start the car (in neutral!)
- Have a friend turn the wheels back and forth, while you listen for the source of the sound.Last edited by DilutedImage; 05-25-2006, 07:24 PM.
Since tie rods come into play for both steering as well as when you go over a bump I'd look at that first. Put it up on jack stands and check for play.
Might help to have a helper hold the steering wheel tightly while you grip the tire at 9 and 3 and attempt to move it back and forth (with the center of the wheel acting as the pivot.) You want no play at all between the tie rod end and where it meets the knuckle.
While you're at it, grip the tire at 12 and 6 and attempt to move it back and forth (with the center of the wheel acting as the pivot.) You want no play at all between the knuckle and where it meets the upper and lower ball joints.
Another check of ball joints and tie rod ends is to take a pry bar and GENTLY try to pry the knuckle/ball joint or knuckle/tie rod end apart --- go EASY however --- you're just checking for play or easy separability, not actually prying them apart! Again, if the two parts move apart a little replace.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>><<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
I have probably the same nasty squeak on my 92 EX. I think my dust shield behind the wheel is bent and contacting the rotor. I need to replace my lower (control arm) shock bushings and probably my tie rods too. Does your car have kind of loose steering too? It sounds like bare, scraping, metal on metal every time I move the wheel or go over a bump
PM me and get it done right!
I know that sound.. currently have that problem.. I haven't pin pointed the exact place but the tie rod bushings would be a good start.. just start replacing bushings .. they are cheap and easy to replace.. if that don't do it then look into the steering rack. that is just the way I approached the whole annoying problem !!
Yeah, I just finished my H23 Swap and wanted to drive for a while before I put on all these Prothane bushings and redid all the balljoints and inner and outer tie rods, but that noise is impossible to ignore at city speeds. This will be my fourth time installing a full polyurethane kit, so it's no biggie. I saw the dust shield bent out of shape when I went to put my axles back in and rebent it. The noise was gone when I got the car running again, but came back two days later. I'll probably remove those shields completely when I go over the suspension and steering. Screw it for now, nobody can hear it from way behind me
