F22B FPR help?
    F22B FPR help?
    ? i was told i cant install a fuel pressure regulator on my f22b dohc nv it has an aem fuel rail on it now. correct me if im wrong but isnt the fuel pressure gauge usually installed ontop the fuel filter by using the banjo nut b/c if that the case it cant be done with that vaccum box being directly above the fuel filter. (how do i make this work?)
    thanks
    dan
    bump someones gotta have an answer for this , please!!!
      if im correct and im not positive so take my word for this the FPR goes on the end of the fuel rail but not posiitive since i have never used a FPR on our cars but if you do find an answer let me know because i plan on using one when i boost
        yah the fpr goes on the end where the stock one is located now but the ? is where does the fuel pressure gauge go seeing as the vacuum box thingy is in the way
          bump for some more opinions please
            all the ones i have seen have the gauge on the FPR
              bump
                FPR goes on the fuel rail. Its where the return and the vacuum hooks up. I think AEM has an extra fitting on there rails to accomodate an FPR.
                  just a dumb question... have you searched the site for an FYI on the install ?? if not some other site should have it because it don't really matter what engine it is for Honda engines are generally the same.
                  Originally posted by Devergote
                  A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                    yah but it matter where the fuel pressure GAUGE goes and thats what im not sure on how to install because it is supposed to go on top of the fuel filter but i cant put it there bc that vacuum box thing is on top of the fuel filter
                      AEM makes an FPR that fits their rails, but I don't know the details on what kinds of fittings or attachments it has. A friend of mine just tapped his fuel pressure guage into the middle of his fuel rail, which looked pretty nice. The filter spot I've seen work fine too. I don't think it really matters where you put the guage as long as it's somewhere between the fuel filter and FPR.
                      PM me and get it done right!
                        have you tried to just put a T fitting on the hose from the fuel filter. I have never installed one myself but have seen it done. most aftermarket rails already have a place for the FPR. does yours have one ?? can you post pics ??
                          what type of gauge do you have ?? b&m..aem..autometer...defi..greddy ?? try this
                          the sst being your guage a basic diagram.. but kinda of what i was talking about earlier.
                            wow thanks i culdnt have asked for it to be explained any better than that diagram, so pretty much any AEM fpr will fit my aem fuel rail or what fpr should i get, one for 91lx or one for the f22b which is wats in it
                              What application is your fuel rail for just order the FPR as the same as you did the rail.
