I just wanted to make sure the h23 exhaust manifold will fit the f22a6 head Im pretty sure it does but I want to make sure ive read post about it but there was a lot of + & - feedback so I just want another opnion. Becaus I found a turbo kit for h23's that i want to get. thanks
H23 Turbo kit
I am building a kit mostly its just i found a h23 turbo manifold its the stainless steel ram horn style and you dont have to loose the dog bone mount or the ac lines. It also comes with a t3/t4 turbo .50 trim and the external 38mm wastegate all for 710.00 shipped i figure its a good deal. still expensive but all new with warrenty I want the t3/t4 because it will support my future plans im buying another f22 and i plan on building it to hold around 20lbs of boost if possible and i just want to turbo my engine for now after I do a compression reading but im sure its fine car runs great. The internals are so clean I replaced my oil pan gasket and the crank and every thing else didnt even have that bronze look and from the header to the muffler are clean as far as you can see i licked my finger and rubbed it inside the down pipe and there was no residue at all but any way sorry for getting carried away but yeah i figured it was a good deal. thanks
Turbo Kit
Hey Kricket,
We are looking to develop an oil line kit for H and F motors. Have you decided which route you are going to take? We would love to see what you have in mind. If you have a second, hit us up with an email at "sales@tunertoys.com" and we'll see if we can help each other out.
Thanks from Craig
Thanks from CraigShift_BOOST
BOOM!
i was just woundering this
the f22a is spaced 0-0-0-0
and the f22b is 0-00-0
the h23 is 0-0-0-0 also???? it looks like the h22 is 0-0-0-0 also?????
but the only the h23 will fit the f22a right???Last edited by smokeeey420; 07-01-2006, 08:36 PM.
