clunking sound in front suspension and highway vibrations
    I have a '91 SE which has really been ploblematic since I have had it (only about 18 months). Anyway, the latest issue is some inconsistent vibrations at highway speeds. I've had the tires rebalanced and had a new CV joint installed on one side (it was clicking). The vibration is still there though and it comes and goes. Some days I don't notice it, others it is of high concern. I also notice that sometimes when I hit a bump a certain way there is a clunk under the front of the car, but I think my other Accords did this as well. I can also rock the steering back and forth and feel the same or a similar clunk. I felt the rubber on the ball-joints and didn't notice any tears (doesn't mean they werent there) and I tried feeling the steering arms (tie rods?) as well and didn't notice anything obviously wrong. Still something tells me my clunking noise is related to my vibrations.
    I'm not sure if this is related, but my transmission's lock-up feature is failing as well. Could the vibration be transmission related?
    Anyway, any troubleshooting tips and "how tos" would be appreciated. Thanks for all the past, present and future help.
    -Fred
    1991 Honda Accord SE (current)
    1993 Honda 10th Anniversary (victim of hit and run ... still in driveway)
    1990 Honda Accord LX (died at HRA-O at 230,000)
    check your tie rods because i had the same noise and i found one of my tie rod nut loose and that will cause your whole wheel assembly to rock back and forth
    R.I.P
      im experiencing a similer problem with my car, im wating to get some money boefer I get it checked
      My Members Ride Page
        I also have the same problem. But I fiquer unless someone says its a major problem I'm not gonna worry about it. I'll wait to see if the problem goes away with some new lower suss. and new rims/tires.
          I just got my car back from the shop...it was doing the same thing! $500 later its still not fixed, but its better. They replaced the right axle and the swaybar linkage...the clicking noise went away but the clunking is still there on the drivers side...I think the other axle is bad also...im going down to talk to garage after work today.
          Rocesride Member Page
            Yeah I had the clicking noise and at first they said I just needed a cv joint but I let it go too long and it ended up being the whole axel. My other cv joint/now axel are going as well and while I don't hear the clicking I hear noise like the thumps here and there and it supposedly from the other axel. So either your whole axel should have been replaced and/or the other one is going as well.
            My 91 Accord F22B DOHC MR
            My 1996 Civic Ex H23A VTEC MR
              your better off just replacin both at the same time...i wish i did! and if i had the time i would do it myself. each axle is only 90 bucks! man those garages rip u off, but i just don't have the time to do it myself
