wont start??
    wont start??
    i swapped over a f22a4 into my a1 about a month ago and when it was all done my car would crank over but wont start so the dude that was helping me said there was no spark and all i had to do was get a new distributor so i bought the new dizzy and same thing nothing changed so i ended up having my car towed to a shop to get some diagnostics and they told me that my computer was bad and there was no signal to the fuel injectors and it would cost $150-$200 just to check over all the grounds and wiring, so should i have the shop take a look at everything or just buy myself another comp
    check over everything yourself first. only use the shop as a last resort. they want to charge so much probably for a 5 minute fix. check EVERYTHING yourself before you have to spend the extra money.
      I think f22a1 runs a diff ECU from the a4. I could be wrong. But check your wiring.
        I think your thinking of the a6.
        You throwin a cel?
        YouTube Clicky!!
          You throwin a cel?
          nah
            sounds like the EXACT same problem I got. I have no spark, and I'm all of a sudden not pumping fuel either
              how long did your car sit mine did that one time. no mtter what i did it wouldnt start..changed all that shit check a bunch of stuff..turned out it had sat for a whike and when i tried to start it the fuel filter clogged and blocked the gas...changed it and it crunk rite up...not saying thats your problem but its a possibility.........later!
                thats for the idea, I'll have to take it off and turn the key on and see what happens cause its been sitting for about a month. but I still need to see why I have no spark, cause it was there before I did my head swap, now that I got the head back on there, I cheacked to make sure before everything else was hooked up, nothing
                  Originally posted by pyro_maniac69
                  my head swap, now that I got the head back on there, nothing
                  not doggin yo man but you didnt bend any valves in the head did ya...eason im not doggin ya is cause i did just that this week in my crx and i bent every valve in the bastard...check your valve clearance...never mind you siad you had park trouble..ummm...coil bad?? sound slike a ground though...i dont know man i just know i need to find a head for a ew/d15a3 block and quick...later. check all fuses and relays...
                    Are your injectors even hooked up right? They run the resistor box like every other car?
                      that toward me or the other guy? If its towards me, I don't have the line hooked up to the injectors, just been turning it on and nothing has been coming out
