Can someone post a pic of the NM speed sensor and or Part# and location
    Thanks.
    Getting a TCM code 15 and erratic down/up shifting in D4 and D3.
    ~ Viva la Roofnips ~
    2006 Evolution MR 13.008 @ 106.7
    2006 WRX Sti (still breaking it in)
    1990 Honda Accord LX-T 15.6 @ 93
    anyone? I'm NOT talking about the VSS (already replaced it). This sensor is supposed to be on the front of an auto tranny on the right side of the car. I know how to test it but I dont even know what it looks like or where it is. I think its also called a Mainshaft sensor.
    Symtoms of my car: Blinking S light - TCM codes 3, 10, 14, 15 (going from memory I havent pulled them in a while). I'm going to check the throttle position wiring tommorow but its not throwing any ECU codes, just the TCM codes. Also the TCM has already had the caps / resistors replaced although it was before I owned the car so maybe they are shot again.
    In D4 and D3 it erratically downshifts / upshifts. Also in D4 when taking off from a dead stop it will not shift to 1st it starts in 2nd. I can manually shift to 1 and then 2 and then D3 or D4 but at highway speeds it downshifts and upshifts constantly.
      http://media.honda.co.uk/car/owner/m...l/400/9-62.pdf
      Having a hard time finding a part number, give me a few minutes
      *edit* There's a mainshaft and a countershaft speed sensor.
      *edit* I seriously can't even find that part at majestic.....call Honda.
        A thousand thanks to accordaffair! At least I can test mine now. Do you think that would cause the problems that I'm experiencing? Has anyone had to replace this sensor? What were the symptoms?
          This is how questions are supposed to be asked.
          Gary A.K.A. Carter
          [sig killed by photobucket]
