my car does not have ABS how hard would it be to convert it and is it worth the money?
Abs
What make and model do you have. Looks like you have an LX in your sig like a 92/93. SHoulda came with ABS unless it was an option. Personally i wouldnt spend the time to convert it just get you some better rotors, SS lines, and pads and call it a day.
No LX'es came with ABS. If you really want it you have to get a '92 or '93 EX.
I would not bother, non-ABS cars have been around, and they stop, don't they?
Plus, non-abs makes it easier to do brake work. I replaced my master cylinder today, but I would not have been able provided my car was ABS equipped.Gary A.K.A. Carter
[sig killed by photobucket]
Originally posted by The G-ManNo LX'es came with ABS. If you really want it you have to get a '92 or '93 EX.
Ahh i gotcha didnt know that learned something new. Master cylinder aint bad for an EX i replaced mine a while back didnt take too long. Just loosen the lines and take the two bolts?? off the brake booster if i remember and pull out. Then bench bleed and reinstall. The EX ABS is like a separate module by the look of it when i took my bmc out.
Originally posted by The G-ManWell, apparently you have to use a different bleeding method to bleed ABS brakes.
I did the normal bleeding procedure nothing special and my brakes worked fine. Got a buddy pumping the pedal, one to dump fluid, and i opened/close the bleeder. Thats all and the brakes feel fine no air or nothin.
Originally posted by NAiL05I did the normal bleeding procedure nothing special and my brakes worked fine. Got a buddy pumping the pedal, one to dump fluid, and i opened/close the bleeder. Thats all and the brakes feel fine no air or nothin.Gary A.K.A. Carter
Oh well it worked for me hasnt messed anything up yet.
I wouldn't even bother converting. My ABS light is on right now, which indicates the abs not working and i seem to brake fine. The only reason i would ever convert or fix my ABS would be, because i had or was going to go through a harsh winter...Audi A4 2.8 Quattro Sport
