Running to much oil. help quick!!!
    Hello, I am doing an oil change and was distracted and accidentaly poured all five quarts of oil into my motor not remembering I was on the fith one. Is this bad for my motor or will I be fine.
    Thanks
    I always pour 5qts of 20/50
    93 Accord LX Sedan (sold)
      It's pretty easy to drain oil, ya know
        You can always get a really long straw and suck some out. Did you check your final level to see what it was at? If its a lil over it should be fine but check the oil level first with the dipstick.
          Go with 10w-30 since you're in AZ. Check your oil and make sure its at the proper level. Otherwise you gotta take off the valve cover and dump some out.
          Or the drain plug...?
            Why would you use anything other than the drain plug to drain oil?
            - Ghosty
            WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
            FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
              That's what I'm wondering. It's quicker & cleaner to use the plug.
                And by the way, we're talking about an engine that Honda recommends putting 3.7 quarts in, right? Drain some now.
                - Ghosty
                  why such a low number?
                    5w30 or 10w30 is what honda reccomends in the older cars. I think the newer ones are 20w50... but I always use 10w30 since it never gets cold here.
                      am I killing my engine by using 20/50? & what does the climate to do with the oil type?
                        I was told that HD30 worked really well for the older cars also. But i am here in bfe and the weather jumps around.
                          I would just run 10w30 in the summer and 5w30 in the winter. And if it is too full it will create bubbles in the oil and it wont coat the engine as well. Check level drain accordingly.
                          SuddenCb7 - 1992 Honda Accord EX Coupe
