H23 manifold with f22a6 throttle body
    I was wondering it i was to use a H23 manifold would i be able to use it with a f22a6 throttle body?? If so does that make sense?? Like am I goin to get any gains, can some one pleas tell me the pros and cons of doing this if it is even possible.
    Thanks
    No
    And search its been covered 10000+ times.
    No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
      The F22 Throttle body is 5mm in diameter smaller than the H series TB, which would probably offset most of the benefit of putting the plenum on.
      The F TB will also not bolt the the H series plenum without modification, as the bolt pattern is different.
      It is kind of a why bother thing.
        The H23 TB is better than the F22 throttle body keep it that way.
        so in order of your questions
        No, bolt pattern is different.
        No, the H23 TB is better.
        There are no pro's to doing that, only con's.
        1992 Honda Accord DX
        Coupe 5spd
        2.2 liter I-4 (code: F22a1)
        125hp @5200 rpm 137 lb/ft @4000 rpm
        (\__/)
        (O.o )
        (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
          thoguth it was two
            It could be, I just used a Vernier caliper to measure them.
            I got 57mm for the Accord and 62mm for the Prelude.
            I saw 57mm posted as the measurement for the Accord somewhere, and it seemed to be posted by someone reputable, so I figured I was accurate in my measurement.
              you cant use a F series throttle body on a H series plenum....thats why you use a H23 upper manifold half on a F22A6 lower...
              some cars have wings cuz they look cool.
              some cars have wings cuz they increase efficiency.
              some cars have wings to keep them from taking flight.
              f1 fan
                aite thanks
                  Got 2 f22a TB's here in front of me, and a micrometer so for the record I'll measure them.
                  Note: I brightened the pics up some so you can see the lcd better.
                    Pretty much what I got too, except my micrometer didn't have the fancy digital readout.
