Neither the condensor nor the radiator fans are working, and I need help figuring out the problem. I've replaced the thermostat and both switches. I've checked all of the fuses in the engine block and the driver's panel block. I've checked the radiator relay (switched it with the power window relay and the windows worked), but I can't find the condensor relay. I've jumped the motors and both work. I've let the car warm up to 1/2 way at idle, and didn't get a reading on either switches. I tried to jump the connectors that plug into the switches and I didn't get anything, however I'm not sure if it's because the connectors are blown or if the switch activates them a special way. Also, when I press the front defrost button, it turns amber. However when I press the A/C button, it doesn't turn green. Neither buttons turn on the fans. Thanks for any help.
PS - I really need this fixed, is there any other forum that I can post it at in order to get the problem taken care of faster?
