Radiator fan & aircon fan no working when the thermo switch are connector only you di
    Radiator fan & aircon fan no working when the thermo switch are connector only you direct connection the fan switch both are working
    when the thermo switch is connector engine temperature running nearing to half both fan still no working ,why?
    under the hood there is a fuse box, look and see which one is for the cooling fans. see if all the other fuses are good too. also turn your a/c or front defrost on and then see if the fans are running.
    turboed cb7 baby
      also there are 2 different temp sensors for that fan too.
      turboed cb7 baby
