I hit a curb and now have 1 degree of positive camber on front right wheel. Does anyone have a suggestion for a product to adjust -1 degree, preferably cheap, as I hope to fix the problem properly in the future.
fix positive camber
Originally posted by accordionI hit a curb and now have 1 degree of positive camber on front right wheel. Does anyone have a suggestion for a product to adjust -1 degree, preferably cheap, as I hope to fix the problem properly in the future.
2) fix what's bent because it could be dangerous.....more than likely, you bent your knuckle which isn't that hard to replace.......you may have also bent the strut, tie rod, wheel, control arm, hub, or front crossmember....and on the 7th day, deevergote rested and called his mom.
Originally posted by fizzbob71) how do you know you have 1 degree of positive camber? you had it checked? if so, he should have told you what was bent that caused it
