no luck searching this one either. sometimes, not always, clutch goes in, stick takes a lil more force than usual to move into 1st. so i go 4th, then 1st, then move the car. doesnt happen always. but what would this be? fluid looks fine, but i can check again. any other ideas?
shifter sometimes sticky?
Could be your clutch goin out if you dont see any leaks comin out of the hydraulic system.
Try greasing up your cables...
Buy a can of all purpose grease, open up the shifter console and grease up everything:
The two cables, all the pivot ball joints, the core...anything that moves, grease that shiz up!
After that, go to your engine bay, look where the pins are for the cables...grease those up too...(top of the tranny)
you might just have sticky cables...try it, it wont hurt, it'll aid your throws, making it smooth as butter...
other than that...if it's not that that is...it could be your synchros being notchy and a pain...
1990 Accord Lx F22a1(Daily) SOLD - will be missed
i had the same symptoms right before my clutch resevoir went empty. check for leaks
dont know if this might help, but i had the same problem on one of my saab's and it was the gate for the shifter....not sure how often or if ever they get out of allignment with these cars, but its worth a try! its an easy fix too! I had to move my shifter to a different gear too, usually i picked 2, and then it would open the first gear gate and it would slide in no problems!
Originally posted by rychas1nothing noted with the engine off that i remember.
check out this thread:
http://www.cb7tuner.com/vbb/showthre...hlight=shifter
you first post sounds similar to what happened to me a while back...turned out to be my clutch. i describe the problem in the thread below:
http://www.cb7tuner.com/vbb/showthre...ghlight=cables
