Tire Pressure Question?
    Well I was checking my tire pressure today when I realized the rear tires were very uneven tire pressures. The front tires are 32 and 31. The rear are 22 and 41. The front tires are from the same set, Hankook Optima's(cheap tires) and I forgot the rear ones, I think Firestone. I was thinking of evening out the pressure of the tires but would it be safe since the tire sets are different from the front and rear?
    Why wouldn't you want to just set them all to spec?
      yeah...I would go even all around...
      My Ongoing CB7 Project
        Originally posted by erikm
        They should be even all around, otherwise you could get bad tire wear. Or mess up a tire.
        93 Coupe........AutoX
          Last time i checked my cousins they were way off the backs were 40 and 33
          and the fronts were 29 and 35 he was getting uneven tire wear.You think some place that specializes in tires would get it right. Just set them all even
            If the tread life on the tires are almost done, i suggest getting new tires...mix and matching tires is not a good thing...the Hankook and Firestones im sure have different treads profiles...
            also, it's wise to keep checking tire pressure once in a while, perhaps once every 2 weeks just to be sure.
            My Accord has new tires after the previous owner had 4 different sets on, with 4 different widths
            1990 Accord Lx F22a1(Daily) SOLD - will be missed
              I just gone done with readjusting them and there is a HUGE difference! The handling is alot easier especially when turning or cornering. The tires used to screech when I took even the slowest turns. My tires pressures are all set around 30-31.
                mine are at 34-36 and they still seem low
