how do i get this damn thing off!!!
    ok my intake manifold is ALMOST off
    its just these 2 bolts that r stoppin me from it
    ive tried every tool i have to get it off nd it wont even budgee
    i even spray WD40
    nuttin changed
    any idea wat to do next??
    here r the pix
    i think its called the EGR valve or summin like that
    my ride
    a 12mm wrench. later.
    Avoiding dirt at all costs
      yeah i noe i tried that
      it wont budge
      i waz doing it so hard i bent sum of the metal on it
      my ride
        If you have a 3/8 inch mm socket wrench with extender you can put another extender in it being that it nice and skinny. Then put some papertowel inside the 12mm socket then use a small prybar and turn it slowly. I think you stripped the nut that was on it thats why its not coming off. Hope this helps
          thnx
          ima try it out in a bit
          my ride
            If you can get a crowfoot on there that would be easier. It looks like a wrench but it connects to the socket and helps a lot.
              yea get an extention and then a long breaker bar, that will work. or even with ur small ratchet, get a wrench that fits the end of the ratchet and then that will lengthen the the ratchet for more torque..
              sometimes i sliightly tighten it and then loosen it as well.
              haha sometimes it is easier when the motor is warm as well.
              Retro!
              Hater
                try a 3/8 ratchet with a 12mm socket and an extension hold the head of the ratchet while your trying to turn it
                the build and demise
                buy stuff i want a new car
                  2 words: Weight room.
                    rofl
                      PB blast , Much better than WD40 Trust me spray it have a beer and go back and turn the bolt im positive it will come off , l8ta
                      Let me know how it turns out
                      -Sean-Noxidea
                      Fore Sale" My Ride "Best Time To Date 14.9 @ 94 MPH ...
                        yeah if your car runs, let it get hot, that helps sometimes. later.
                          a really big adjustable cresent wrench, thats how i got my oil sensor guage off my block.
                            torque wrench with a really long extender
                              You don't want to use a torque wrench to loosen exhaust manifold bolts, you'll most likely have to get it recalibrated if not break it.
                              1991 Honda Accord, 2.2L I4
