oil used
    oil used
    hey my cb7 uses to much oil i think the engine that i have is the:
    F22B2 (Block)
    F22A1 (Head)
    F22a6 (Cam & Intake\Ex Main)
    it uses about 1q every 4000 miles i just put in the new engine in about 10 weeks ago
    does anybody know what may be the problem
    da9b16 is a great seller very quick shipping and great parts
    well i dont think your car has vtec right unless it does then thats when you burn up more oil or you may just have a real slow leak somewhere that lets oil out ever time you drive your car i mean its a honda you can run these cars on one qt of oil and you should usualy change your oil every three thousand miles or so so i wouldnt worry unless its leakage becomes realy noticable then i would worry (its not like oils expensive)
    TEAM JND BITCHES
      and also do you do the oil change cause if u do then you may have strips the threads a little for the bolt on the oil pan from over tightening it then and if that may be the case then i would check for repair kits for that prob or you could just put some silicone or somthing over the bolt and help stop the leak and just rip it of at the oil change
      TEAM JND BITCHES
        is there any odors going out from the motor or exhaust (burned oil?)
          Where does it say he has VTEC? B2's have no VTEC. You replace all your seals and such? Done an oil change yet?
            If it does turn out to be smoking, get down on your knees and start praying to the internal engine component gods...giving extra attention to the piston ring god.
            When I bought my '91 EX 4 weeks ago it was losing oil at about 1 litre for every 500 kilometers I drove. That sucked. But after some head scratching it was determined that the expletive who put the oil pan on last had bolted it on finger bloody tight! Who does that?!?!
            Anyway, do what NAIL05 said and check all your seals. Also, put some cardboard under the car at night to see if you have a leak.
            1991 Honda Accord EX (Canadian)
              man nail05 calm the fuck down im just tryin to be helpful you ass
              TEAM JND BITCHES
                Obviously some one wants to be banned. There's a reason you're in the noob section so take the time and learn from people that aren't. I didn't take what Nail said as being offensive either so you might want to do some chilling yourself. You made a nonsensical post so get over it.
                Cats on ice, your post was also irrelevant. I know we're all trying to make 30 posts but that doesn't mean post filler crap or you haven't earned your right to be in the other sections.
                Back on topic. Does it appear to be leaking from the top or from the bottom? Is it only on one side? I'm not familiar with this swap so help me out here: do the head and block have identical oil passages? If not you should have plugged something on the head with Hondabond or J-B Weld,\. If they lined up then cancel that out. Basically you're just going to have to start looking around and replacing things you thing may be the problem. Isolate it to one area if you can. You're not going to waste money by replacing seals and gaskets so don't get too bothered if you replaced something that doesn't solve the problem.
                  As mentioned i was pointing something out...I dont see how that sounded like i was being an ass...BTW if i wanted to be one i would but its the intranet so theres no point.
                    I guess Iwas being random and useless...Oh well. I'll now try to redeem myself
                    Here's one question..... The coolant in your Radiator Overflow Bottle: it hasn't developed a bath tub ring, or hasn't started looking like a Dunkin Donuts Coffee Coolata; has it??
                    It so, you've found where your engine oil has gone.
                    Also check your air filter for signs of oil.
                    If it turns out it IS leaking under the car:
                    If it's leaking on the drivers (left as seated) end of the engine it could be leaking from either:
                    Front Crankshaft Seal (inside Timing Belt Cover)
                    Front Balance Shaft Seal (inside Timing Belt Cover)
                    Front Camshaft Seal (inside Timing Belt Cover)
                    If it's leaking from the Passengers (right as seated) end of the engine it could be leaking from.
                    Rear Main Crankshaft Seal (from inside the bell-housing)
                    If from the engine's rear:
                    Oil Pressure sending unit
                      Dont really see that often and it wouldnt really be that obvious. Another good question to ask would be does your car blow blue smoke? You can go do a compression test on all 4 cylinders also do diagnose your oil situation also to see if its your rings and such. But anyway cats_on_ice gave you somewhat of an idea to start checking but i would say get under your car look for obvious blobs of oil, clean it off with some brake clean or something drive around for a while get back under the car and see if you can pinpoint a spot.
                        sorry
                        hey sorry for what i said just kind of pissed off /was at school at the time so i appologize to Jarrett and Nail05 i was out of place i was trying to talk when i didnt no alot about what i was trying to talk abbout was only trying to be helpfull in the long
                        sorry
                        TEAM JND BITCHES
                          sorry
                          Shit happens no bigge.
                            thanks for all the help #2 & #4 cyl are shot (oil on the spark plug) i fixed and put in new rings works great now but i fore see a h22/h23 hybrid swap
