Shifting Trouble
    Shifting Trouble
    Yo,
    I just picked up my 93 EXR recently and have a little trouble shifting.
    It seems that the clutch doesn't disengage completely, resulting in a little bit of almost-negligible grinding here and there.
    Tying into this, I can't seem to shift into first with any ease. If the car is stopped, for example, and I try to shift into first it doesn't go. If I rev up to 3k and then shift as it spins down, no problems. Same thing for reverse except that it's not a clean shift if I shift into reverse while the engine spins down; nasty nasty grinding noise.
    I'm thinking it could be something wrong with the mesh system if not with the clutch itself. How would I go about checking the clutch/mesh system, etc.?
    93 EXR
    In the works ^.^
    Todo:
    Blower Unit replacement
    Climate Control Knob replacement
    Deck install
    SRI install
    New Brake Pads
    Rotor regrind
    Wheel polishing
    New struts (?)
    New springs
    How many Kilometers does your newly aquired ride have?
    1991 Honda Accord EX (Canadian)
      CHeck for fluid in the Clutch master cylinder. Might be running a lil low and prob leakin somewhere. Might wanna change your tranny fluid to see if that helps a lil.
        Thanks for the tip, I'll give that a try when I get back to it. (Out of town for the moment.)
        298k kms on it. I'd complain, but the vehicle was free
        93 EXR
        In the works ^.^
        Todo:
        Deck install
        SRI install
        New Brake Pads
        Rotor regrind
        Wheel polishing
        New struts (?)
        New springs
          could be a problem with your synchro's...
            That's a lot of miles man...
            It really does sound like your syncros...
            (Is your clutch pedal very mushy? meaning soft?)
            ...Check these for maintainence:
            1)Master cylinder for fluid level in reservoir.
            2)Slave for leaks.
            3)Clutch slave hose for leaks - it's rubber and Canadien weather isn't to friendly in the winter, thus can dry-rot the rubber clutch hose.
            4)Manual transmission fluid---you may want to flush and get new fluid...
            Inspect those 3 first. You may want to bleed your clutch, get all the possible air out. Search here, im sure there is a DIY.
            Now, as for your shift linkages...
            take apart the shifter console. Go buy some all purpose grease and grease the snot out of the shifter cables, all pivot joints and as well the shifter pins on top of the transmission.
            If that didnt help out(bleeding clutch & greasing) then your syncros are to blame...
            bytheway, how is your clutch? does it slip? grab well?
            1990 Accord Lx F22a1(Daily) SOLD - will be missed
