I Have A Problem, My dome light or my other light on my right door doesn't work but the left door light works fine would anyone know whats wrong with it? the fuses are all good...and i dont know whats wrong i bought the car like that...
Dome Light Problem
Theres a switch on your door jamb which allows the dome light and door light to come on when they are open. That could be your problem.
The two doors have two separte curcuits.
When you open the left door, its lift comes on and so does the dome lift. If you open the right side door, its light comes on and so does the dome light.
Remove the screw for the switch, they'll be ONE wire attached to it. Put that wire to ground, if the lights come on, its the switch (or whatever is attached to the door to activate the switch, I can't remeber if there is anything), if it doesn't come on, its something else.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Hmmm thats odd. You sure the bulb is the same one? Have you checked the bulb itself to see if its good?
That switch from the dealer is like $9 and I had the same problem on my old Accord.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
