fuel pump relay help
    the fuel pump relay or the fuel pump on my car went and i figured i would try checking the relay first soi was wondering if anyone has done this or knows how 2 any info on how 2 dothis would be great the haynes manual isnt a bug help so i hope someone on here can help
    visit www.fourgasm-motorsports.com
    For sale-Brand new stock f22a clutch and also have stock flywheel pm for details or prices
    The PGMFI relay is located wayyyyyyyyyyy up underneath the dashboard on the driver's side above the cruise control module. It is a larger gray box with an orange bottom. I would recommend removing the C.C. module for easier access. Really, an easy test is setting your car in the sun for a while and watching for your PGM-FI light to turn on for a few seconds when the key is in POS II.
      i changed my relay like 2 weeks ago, its way up there under the dash but very easy to change
      My Members Ride Thread
        Its way up in under the dash in the corner its a gray box or black box blockin it on the upper left under the dash. you may have to push a couple of wires out of the way. Just to get to it i think its a 10mm screw i think and its a brown little box . If your laying flat looking up under the dash its under the right side use an extention to get to it.
          If you have cruise control it would be easier to move the box aside so you have some room.
            it is e-z to change but a dick to get to
