Blown F22B Turbo
    Blown F22B Turbo
    just finished the custom turbo and blown the motor with 4.5 psi pisses me off now im gonna have to put the single-stick back in fuck turbo
    more details?
    what was your setup? there is probably a good reason it blew up...
      my buddy bought a HF manifold for his ZC and was gonna turbo it and didnt fit at all so he tried on a single cam f22 and fit pretty good. so we put the manifold on the F22B and stuck a garrett t3 on it and all that good shit but im pretty sure the FMU was the problem cuz it wasnt hooked up
        Even if it was hooked up it would have been the problem. Ditch it and get an ECU next time
          Did it run out too lean.... Sorry, not running boost so I'm just curious.
          1992 Accord LX - SOLD
            clearly, he didn't have any management, so it ran lean AND had advanced ignition. Bye bye motor, all the tuners fault
            Shift_BOOST
            BOOM!
              yea it ran lean i saw how my buddies supercharged gsr's FMU was hooked up and i found the problem
                chipped p28 with crome dont fuck around with FMU, ECU ftw.
                  did u learn your lesson? I think you hold the record for blowing up an f22 with the lowest amount of boost so far. Pix of the carnage?
                    lol. As everyone said thats what you get for not using any engine management
                      lol, hahaha good onw MRX
                      i actually wanna see the setup with that HF manifold...
                      Formerly 91AccordExR33
                      11.68 @ 127mph
                      417whp/375wtq
                      Sold: 8/2016
                        same
                          wouldn't the cause of the engine blowing up be the timing not the fuel delivary???... i've set up less then 5psi turbo's on lots of different cars with the stock ecu, fuel rail, injetors, etc..., i would just have to retard the f@ck out of the timing.
                            its neither one nor the other...its the combination of the two. not enough fuel, and over-advanced timing both cause detonation
