Hheellpp!!!??!!
    Hheellpp!!!??!!
    My car died today. thought I flooded it but she is getting no spark. What could be the problem? I'm thinking it's my distributor, but, i dont know. All my fuses are fine, she just wont kick. Could it also be the ECU? Any help would be appreciated.
    My car also makes this weird vibrating noise/felling when I back up. What the hell could it be?
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways-Jack Daniels in one hand-chocolate in the other-body thoroughly used up-totally worn out and screaming "WOO HOO!, What a Ride!
    Check the coil.
      yes check the distributer/coil. Might be the ignitor.
        Right up my alley.
        Pull the distributor cap. Ground one end of a piece of wire to the block and hold the other end 1/4" away from coil secondary post (little spring), then have someone crank the motor over. If there's spark your coil's good.
        While you got the cap off check the ignitor. Connect test lite to + post on the battery and place test probe on - side of the coil. Crank the motor over if it blinks, it's good.
        You can also check your plug wires for spark by pulling one sticking a screwdriver 1/4" away from socket and crank the motor, if you get spark your coil is good.
        Oh yeah as far as the vibration I'd check the rear motor mount.
        Good Luck
        Jeff
          Yeah that vibration is more than likely your rear engine mount. And seeing as you have an automatic it will cost you around $50 for the part at your nearest AutoZone (the manual one is like $120).
          As far as the ignition problem, check and double check all your fuses, grounds and relays, and do all the checks mentioned above on the dizzy. Hope this helps. Peace.
            check battery, alt, coil...it sounds electrical to me.
