Is it possible to put in a K engine in CB7's? Like a K24 or sumthin. Damn, that would be an Accord Euro-R (TSX) conversion. lol.
K-series Swap
rickyduckworth
Originally posted by 92DXIs it possible to put in a K engine in CB7's? Like a K24 or sumthin. Damn, that would be an Accord Euro-R (TSX) conversion. lol.
yeah, no mount kit yet and probably won't be one for the next year or so, but if you can make a mount kit and header that will work, either your or rywire.com will do your wiring, and the rest is just money and copying the EK swap basically....
i was about to start this but money became an issue........you can easily spend $3000 + whatever the motor costs
you have to redo the fuel system completely
you have to redo all wiring and you can't use an obd1 ecu yet
different tranny and axles, etc
basically you have to make everything work with the k series.....not a lot of what you already have will work with it
to use the k24 you have to get a throttle body and plate from a type s and use that throttle cable since the k24 uses an electronic throttle
As long as you or the shop you go to has good fabrication skills you can put any engine setup that will fit in your cb7. I actually have blueprints and plans i came up with to drop an F20C from a S2000 into an accord. Also a SR20 into an accord. The sky is the limit.Arcadia Green Crew Member #9
