Clutch
    Clutch
    What clutch do you recommend for our cars i have a 1992 LX.
    XTD isnt bad at all. Been discussed a lot on the forum and there cheap. You can find em on ebay.
      Thanks i was backing up a steep hill last night and i think i messed mine up. It feels really soft i cant tell when it engages i just kinda guess i will check out the XTD.
        Feels really soft as in clutch pedal has no feel? Do the gears go in fine?
          Yeah the gears go in perfect.
            You might just have air in your clutch master cylinder. Pop it open and see if you still have any fluid in there. Does the clutch sometimes stick to the ground?
              No it never sticks to the ground where is the clutch master cylinder?
                Its next to your brake master cylinder. Staring at the engine from the front its on the right side of the firewall. You might be a lil low on fluid or something.
                  Alright ill go outside and check it right quick. Thanks.
                    Ok i went outside to take a look i see two containers but both of them say something about brake fluid on them which one is my clutch master cylinder.
                      The smaller one.
                        Ok how much should be in there? Is there a line? What color should it be?
                          Yea if you look on the case there should be a line that says Max on there. If its not all the way full just put in some DOT 3 brake fluid.
                            Thats wassup ill check that.
                              Thanks it was a little low. If feels better also i must have burned it all up last night.
