Tranny and Egine stuck or seize when on steep road
    i notice tranny is stuck or not engage to engine when ever i go on steep road.even a slightly steep road if a real steep road my car run like a turtle wid WOT....anywzy the.engine RPM and Speedometer needle are stuck. when it happen i push the gas even harder and no power was transmitted. engine RPM not increasin also w/speedometer needle. ....I usually solve this problem by puttin in D3 and back to D4..btw i do have a bad CV Shaft..but not sure thast the prob....
    MY 1n2 CB7
    That's wierd!
    South Texas M_thaf_cka, that's where I stay!
    Check out my Frost White CB
    http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
      Are you saying its not downshifting when you want to. What do you mean your speedo is stuck?? As in its not working?
        Symptoms like your tranny is slipping in 4th gear under a load? check AT fluid, see if it's low and burnt. If fluid looks fine. Could be slipping clutches in the auto tranny, time for a rebuild/replacement. Get an opinion from a tranny guy though, one that you trust.
        And replace the cv axle too. It's only like 69.99, and it's hard to diagnose problems with known-bad parts installed.
        Not sure what to say on the Tach and Speedo guages. Do they EVER move, from the time you start the car? need more info here...
          thnx for the input...well my Tach and Speedo gauge work fine..its just that when the tranny is slip or not egnaging or transfer power to wheel...the engine rev louder but RPM needle in not increasing...it happen sometime on steep freeway around 60mph+..i Check my ATF and its pink and full..
          Thnx
          MY 1n2 CB7
            possibly needs a rebuild
            My Members Ride Thread
              Is your tranny flashing any codes?
                yeah check the codes... that's one messed up problem, almost sounds ECM related
                インテリア Coupe
                HighwayStar - /super highway/stunt driving/transport service/fast delivery/
                NightOwl - Nocturnal posting master
                2.0LPlus Crew - Member # 1.5
                Anti-Tree Mafia - stop hitting trees/to young to die
                FG Civic.com
                  no there are no CEL or D4 flashin...everythin seem fine
                  MY 1n2 CB7
                    Hmm id still jump the TCU just in case there are codes stored inside you know? It might not be a permanent code but something could be stored in the TCU.
                      This is just a guess I am throwing out, but could linkage on the transmission be loose so as it isn't engaging D4 properly, and it is getting into Neutral? Just a thought.
                      Dan
                      For Sale:
                      1995 Accord EX wheels with center caps
                      4 Lug ITR wheels
                      1995 EX complete rear suspension with disc brakes.
                      Email me if interested. rawkus2g@hotmail.com
