See and someone here could have gotten you a perfectly good one for 40 bucks. Well at least it works.
Sports Light Tranny Problem
Originally posted by TampaLouHey, I'm also having the same problem with my tranny, I'm even getting the same codes. Did changing the TCU fix it?
Im wondering what would cause this? I'd like to know if it rained between the time it ran fine and the time it started acting up? I used to get this problem only when it rained. Now it's all the time though. Also, do you have any leaks in your trunk? And do you have oil on any of your engine wires, specifically the ones that are on the passenger side around the tranny?
Thanks for your time
Lou
I do get water in my trunk from the rust hole on my right rear quarter panel. I do have oil grease and whatever debris you get from driving or previous oil leaks. But gathering from what post I read for some reason the tcu and vss are what go bad even from normal driving.
Hope this helps. Sorry for the delay in response.
Originally posted by DjSpeedySee and someone here could have gotten you a perfectly good one for 40 bucks. Well at least it works.
I'm having similar issues and maybe someone could shoot me some help... My sport light is acting crazy just like theirs. Sometimes its on, sometimes its off, sometimes its goes on and off. when I pulled the fuse on the TCU and reset it, it would work fine, for a while. I went to the junkheap and got a tcu from a 91 lx (i have a 90 lx), which is think are the same. for 2 days it worked fine, and today its going to shit again. I have not flushed the tranny fluid because if resetting the tcu fixes it i figure it must be electrical...any other ideas on what to do about it?
thanks
Ven
:::edit:::
oh yeah, i have jumpered the service connection and it didn't throw any codes at all. and now resetting the tcu wont fix it ;(
i have the same problem that you all seem to have also, from waht i have found on the internet it could be the main relay(i think). from what others say the solder can heat up and it could need to be re soldered. mine barely ever happens, only after it sits for a while. i could be the TCU also but then i would think that it would always happens and mine goes away for a while. hope this help, im not an expert but that is what i have heard from others
Here is a great site for common problems on our cars.
http://techauto.te.funpic.org/transmission.php.
Mine started fine even with the TCU unplugged.
Originally posted by mainecrabHere is a great site for common problems on our cars.
Yes you can start your auto accord with the TCU hooked up.Last edited by patastinky; 06-29-2006, 01:13 AM.
Help
Ok my car has the sports light stuck on and in the last few weeks it has did some weird stuff like flash and shift by its self and mainly not shift and start in a high gear or some times low gear and some times just go away. I flushed the trans and cleaned the solonoids and tested them all at 15.5 ohms. I took out my TCU and opened it up to see a brand new looking circuit board. I cant get a code from it the TCu goes red light and the SSports light stays on. The weird thing is if i drive it for a wile it will sometime go away. I will go away for 20 30 min if i unhook the neg battery cable. Everything points to TCU but its not burnt or anything inside i even took pick of inside. It seems like a elec. problem. Please Help
