modifying DSM 450's for f22
    OK, I have searched forever for this and cant find it. I want to get DSM 450 injectors, and I know you have to modify the O rings to fit my f22a1, so I was wondering if anyone knew exactly what to do (also if anyone wants to sell 4, PM me ).
    P.S. Does anyone know where I can find a pinout diagram for an obd1 ECU
    Thanks
    turbo wagon sleeper
    you simply make the inner diameter of the seals bigger..dont make it harder than it really is
      Do we put the resistors inline with our cars?
      turbo wagon sleeper
        our car already has the resistor box and all of that done.. the additional wiring is for the civic and integral folk.. also.. ive done it using the stock o rings.. just use some force and they will go in just fine.. but if ur set on being anal.. buy a new set and dremel then bigger... now the ones that come i believe are hard plastic.. i dont think they no longer carry the rubber ones.. i read something about this on homemadeturbo.com...
        Praise The Lowered...
          so ugh.. wikkedv16.. how rough are u being on those O-rings
          <3 -ivie- <3
            I orderd my rc 550 for a dsm application, and they fit in there just fine, just push a little bit, I would assume the oem dsm's are the same, just like WiKKeDV16 said. L8r
            Turbo H23a3 build has begun
            01-01-2019
              thanks guys, I think I got eveything straight now.
              turbo wagon sleeper
                sorry to bump this but i just wnated to confirm...direct fit and everything??? Fitment plus electrical?
                  Plug and play, 100% bolt in, plugs in etc with a tiny bit of force, but not enough to worry about. L8r
                  01-01-2019
