I searched and searched and cant find n e thing about the sport button that sits on my 91 accord gear select. does it increase rpm range or deliver more fuel or what
sport button on AT
Lets you rev higher...well thats what i noticed when i had my AT accord...performance wise i didnt feel much of a change.
The sports mode means that it stays on one gear a lot longer than normal before jumping to the next gear. Example, on normal mode, when u rev up to 2000rpm it changes gear. When sports mode is turned on, it'll only change gears on 3000rpms or so. U can still rev as high with sports mode turns off Hope that info helps I agree completely with deevergoteEx rides:
2 x 92 Accord CB7 manual: F20A
JdM 97 Accord Sir-T: H22A
99 Mitsi Lancer Evolution 6: 4G63T
and a few others not worth mentioning...
Current:
98 Spec Integra Type R 4 door
www.cb7tuner.com, the best place to be
Originally posted by Gato-FFThat button is basically like an "overdrive". It lets you rev higher, like a higher shift point. I basically use it to pass other cars on the highway. You should see the "S" light on your cluster, and if you dont see it is because its not working properly.Honda-Tech Username: Lostcb7
The cb7tuner.com OG.
Originally posted by JDMcb7Not really like an overdrive. Overdrive is used to give a car better mileage on the interstate. Low RPM's at higher speeds.
It does increase the shift points. I think it also changes the lock up points for the converter since that is electronically controlled also.
It will make the car quite a bit more responsive under part throttle applications because it has a more aggressive shift pattern, and is usually in a better part of the power band.
The upshifting is actually dictated by vehicle speed (i.e. it won't grab 4th gear until you are traveling at least 40MPH, regardless of throttle position, under most circumstances).
I disagree with the durability statement though. It isn't shifting harder or holding max revs longer, it is just a more aggressive program, and everything else adjusts accordingly. I have used mine regularly for 150,000 miles now and haven't had a single problem. The tranny was designed to accomodate it.
Originally posted by deevergotePerhaps the accelerated wear I've heard of isn't a result of the sport mode, but of the driving habits of those using it...
I think using Dexron-II is ultimately a large contributor to their failure too. I don't know if it directly kills the tranny, because I use Honda ATF,but it sure does mess up the shift quality. The ancient Honda Tech I know, is not a fan of using that stuff.
Originally posted by owequititIt does increase the shift points. I think it also changes the lock up points for the converter since that is electronically controlled also.
Originally posted by owequititThat could be. I think maintenance is the biggest issue. I do change my fluid regularly, which I know a lot of people don't. I have seen many non sport equipped trannies fail too, so I am sure that is the gist of it.
