Short-shifter
    Short-shifter
    Are short-shifters worth it? If so, what brand do you recommend for the price range of $50-100?
    And what does the flywheel do?
    If u know how to weld ill send you a fushigi short shifter i bought for 55$. It just needs to be welded together. 20$ shipped and it can be yours
    The flywheel is a large steel or aluminum disc. It acts as a balance weight for the engine, dampening engine vibrations caused by the firing of each cylinder and provides a surface that the clutch can contact. The flywheel also has teeth around its circumference for the starter motor to engage and crank the engine.
      adding on to what maple said..the flywheel also keeps the pistons in motion after the power stroke because of its weight..best place to learn abt cars if u dont have much knowledge abt them is howstuffworks.com ...they usually have illustrations and flash animations to better help u understand it..or u can always just ask most people here..
        From what I've learned on here, there's a way to make your own "short shift kit" from cheap parts that doesn't cost hardly anything.
        Here's a DIY for it...Short Shift Kit
        I found it here BTW so have fun!!
          I love my Neuspeed piece. I just did the shifter basket flip to lower the height a little bit to avoid clearance issues.
          Well worth the $35 I spent for it used from a member here.
            I did the DIY short throw shifter that's on here. It's good and cheap if your on a budget. It only shortens the throw though, not the actual shifter height. However, it still made a big difference. But overall, yea, I'd say they are worth it, depending on how important that aspect of your car is.
            PM me if you found this!!
              im glad i came across this because i know that you cant buy an actual shorter shifter like other cars you can only shorten the THROW but it appears people have figured out how to do whats needed so im gonna have to check into those DIYs
              thanks everyone
                So basically, we're replacing these brackets and moving it up.
                Then we're bending this forward:
                If I don't have a drill press, will a hand drill suffice?
                  www.pspectuning.com
                  True short shifter for our cars, and I believe it's 220 shipped. Check it out, quality piece.
                  Coming soon....
                    awesome find,anyone know of someting in similar quality but less price,if not then ill let yall know and post pics after i buy this kit i think
                      The brackets you see are the new ones.
                      No drilling required.
                      2003 Maxima SE Titanium Edition
                      1993 Suzuki GSX1100F 136bhp
                        thats pretty sweet i wish i could find one in a junk yard lol (im a junk yard ho) lol
                          The Pspec unit is top notch. It is $180.00 for just the shifter shipped and looks to be worth every penny (I haven't installed mine yet).
                          There is also a group buy on here somewhere that my provide you with a discount.
                            $180 is a bit steep compared to the DIY though...
                              Yep.
                              The DIY will cost you $5 including the coffee you buy on the way to Home Depot.
