Just want to sort of get an idea from you guys. For those of you that have oil leaks. Where do you have them? Can you tell where your car is leaking oil from? Mine just recently(4 months ago) started to leak oil. Its a 93 ex with 139k. The engine(jdm f22a) has less miles, not sure on an exact number, but I know its less than 100k. I have an oil leak coming from what looks like between the head and block towards the front of the engine, next to the timing belt cover, but i cannot trace it. Now I've been chasing this thing down trying to pinpoint it . Basically I'm trying to figure out what the most common spot is for our cars to leak oil. I did a search but pretty much came up inconclusive. so what do you guys say? Where is or where do you think your cb7 is leaking oil?
Oil leaks
if you suspect its coming from inbetween the head and the block near the timing cover, clean the area with a degreaser (simple green works great) and when ever you come back from a drive, take a look and see if that will help you further pinpoint your oil leak. Most commom oil leaks are the valve cover gasket and oil pan gasket. There may be another common one but i think thats it for now.
-Andre
Yeah I changed out my vcg a while ago. I used a felpro vcg. It says on the box thats it a permadry seal and requires no sealant. Actaully it says on the box not to use any sealant at all. However in the haynes&chiltons it says use sealant. wtf? What type of valve cover gaskets do you guys think is best? Should or should not use sealant with a felpro?
I just use most of the time whatever the autopart stores have in stock, I don't really favor brand on just replacing one gasket. I'd also just use some nameless gasket sealer they have it seems to work well and I've had the same tube for a while. lolHi, I'm Shippo and I have a problem. I keep buying CB7's.
The one big thing I have noticed is very important to keep gaskets from leaking is making sure that you torque down all the nuts evenly. If you have one side of the valve cover tightened more then another, it will leak. And I have heard many, many positive things about Felpro gaskets from a few mechanic friends.
DanFor Sale:
1995 Accord EX wheels with center caps
4 Lug ITR wheels
1995 EX complete rear suspension with disc brakes.
Email me if interested. rawkus2g@hotmail.com
You should NOT use sealant with the Permadry Felpro. The reason your Chilton's says that is probably because it was first published years ago before anyone even heard of Permadry gaskets. Gasket makers like Victor and Felpro are continuously improving gasket designs and your gasket is specifically designed to be used without silicone. The head on your car has machined gasket surfaces for the spark plug tubes and the main valve cover seal also called a "worm" gasket because the gasket fits in a machined groove around the circumfrence of the cover. Just make extra sure that the gasket surfaces are completely clean and dry before you install.
Originally posted by swerveYou should NOT use sealant with the Permadry Felpro. The reason your Chilton's says that is probably because it was first published years ago before anyone even heard of Permadry gaskets. Gasket makers like Victor and Felpro are continuously improving gasket designs and your gasket is specifically designed to be used without silicone. The head on your car has machined gasket surfaces for the spark plug tubes and the main valve cover seal also called a "worm" gasket because the gasket fits in a machined groove around the circumfrence of the cover. Just make extra sure that the gasket surfaces are completely clean and dry before you install.
Thanx everybody for the info. I appriciate it. I guess I will be reworking a vcg here in about....14 hours....lol..
First wash your motor so that everything is clean. Then go from there and try to find the fresh oil leak. My first guess would be checking your distributor O-ring, very common for these cars. They have to O-rings one inside the distributor housing and one at the distributor shaft. If theres oil inside the distributor change it ASAP.
Mine leaked from the VCG and from the oil pan gasket. Just a heads up it can be from more than one placeOriginally posted by deevergote..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
Bought from:93a-lude, bruno8747, soysauce
1993 H22A cb7 <3 miss you
04 WRX stg 2 sedan
Current - 02 WRX stg 2 wagon
I just replaced the leaky front main crank seal on my f22, that and the valve cover gasket and pan gasket were all leaking. For good measure I had to do the balancer shaft seal, the cam seal, and I had done the rear main when I had the trans out for the new clutch. Now at 235,000, it doesn't leak a drop!!!1992 Accord LX - SOLD
I had my oil cooler o-ring leak.....got that fixed now noticed that my valve cover is leakin but that's my own fault i didnt change it when i did sum thangs to my head....but ima get it change when it gets alil warmer bc im plannin on running nitrous.....it's not dat bad just a lil leak....but i check my oil every otha day just to make sure....but on my old f22 my oil pan leaked pretty badly....Accord Hybrid
