Tightening alternator belt
    wat bolts am i supposed to tighten..people sya theres these 2 bolts but i have no clue what they r talking bout..ive asked this question several times..gotten several diff methods..please help...rmeber its the beginners forum.s.o u cant flaaaamme!!!lol
    I believe theres 2, 1 to tighten (Secure) the altenator, and theres another 1 to move (adjust) the altenator.
    1992 Honda Accord Owner
      buit which bolts am i supposed to tighten
        Theres only ONE bolt that you need to tighten and that is the bolt to the right next to the bolt that says leave tight (its to the right of it), however there are a few bolts that need to be loosened in order to allow the alternator to pivot when you adjust the slack.
        *Edit* It's the same process on the f22.
        My H22A SWAP JOURNAL
        Members Ride
          DHN, which motor do you have?
          1992 Accord Coupe 5-Speed
            Easiest way to check get you a light and you will be able to see a visible screw with threads. That would be your adjuster. If i remember it was the right one that was the adjuster and you have to loosen a 12mm bolt that secures the adjuster in the back as shown in the pic. Dont forget to break loose the big 14mm on top.
              Yes. The right 10mm nut is the adjuster and I loosened the 14mm nut of the top alternator bracket. What I cannot find is the 12mm bolt that secures the adjuster in the back. Do I have to access it from underneath?
                Its kinda hard to see but you can feel for it. You can get a better view if you push the cruise control to the side. But you should still be able to see it without moving might need a lil light or somethin.
