h22 swap help.
    h22 swap help.
    about to get an h22a swap soon and just confused on these things and thats all.
    if the downpipe is too long to bolt directly into the cat what type of full exhaust or cat-back do you use that'll fit with no problem?
    what kind of belt do you use for the power steering?
    what prelude ecu will work with an auto h22?
    You'll need an automatic P13 ECU.
    I believe you can use the Prelude PS pump with the Accord bracket. You'll need a custom line (I think they sell the necessary stuff at Autozone) to get it to work. I may be wrong there though... wait till someone confirms that before you take my word!
    The exhaust will need to be custom. Rumble into a muffler shop and have them weld something for you. I had the shop that did my swap weld a new flange on my piping, but it didn't last long at all (a month or two tops).
    Also, if you need help at a fair price, h22sparkle is your man
      I used the Prelude power steering pump with a full Prelude Si VTEC line, just a little bending at the bottom end and it fit. And as for exhaust, my Greddy header bolted up fine to the stock exhaust (since I ran the stock exhaust for a few weeks).
      Originally posted by Junior Smurff
      Nevermind guys, google search works wonders!
      I don't have road rage, my car just goes faster than yours!
      Accords are for winners. And Grandmothers. But mostly winners.
      I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
        get an f22 pump with an h22 bracket with an h22 belt, also ull need the h22 cat
          You can use the accord bracket with the h22 ps pump. The only difference is the bracket that holds the ps pump is only gonna have two screws holding it on. You can prob use the H22A ps bracket with the h22 pump but dont quote me on that. Why would you need an H22 Cat? It will bolt on to the stock cat just fine well mine did at least since i got an aftermarket header. USDM h22a downpipe will work also.
