My car is a 1991 LX, original f22a1 with 217k.
Failed to check the timing belt when I got it, it ended up snapping on me one day on the way to work, and, believe it or not, it was the original T belt from 1991, insane.
Either way, I ended up buying a junkyard head out of a 90 f22a1 with same miles, new head gasket and studs and when it is done, all cylinders were on 175 and cyl 3 used to be 75psi, ran okay despite that. Fast forwarding the story, yesterday I got my head from the machine shop, installed it, torqued everything properly and the car runs worse than before, and this time 178psi on 1-2, 0 psi on 3 (dry and wet comp test), and cyl4 came to 150. Checked injectors, retorqued the head down to 79lbs instead of 78, checked valve lash, intake manifold gasket, vacuum lines, and even tried playing with timing a bit until I got it 100% lined up in TDC on both the crank and the head with zero slack on the belt, pretty much so perfect it cant mess up.
Even after those adjustments, cyl3 does not get any compression, engine turns on but runs like crap, when accelerating it you could hear cyl3 being inactive, the car does not stay on by the way, and if it is put under load forget about it, not enough power, car is pretty much undriveable at this point.
What could it be, ... cyl3 piston rings? small hole or crack in piston? impossible but vent valves again?
I checked that piston and it looked great, cyl walls were in amazing shape. Any pointers would be great.
