My 93 auto seems... slow. It hits a wall after 80 and completely tops out at 107, and that took a LONG time to get there. I deleted the old cat so thats not the issue. I hear alot of people with stock auto CB7's getting over 130. What could be the issue?
Loss of power
Where do you stand on normal maintenance? You know your engine has good compression? Clean air filter? Clean fuel filter? Correct fuel pressure? Good plugs, cap, rotor, wires? Ignition timing? Valves adjusted correctly? Brakes not dragging?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostWhere do you stand on normal maintenance? You know your engine has good compression? Clean air filter? Clean fuel filter? Correct fuel pressure? Good plugs, cap, rotor, wires? Ignition timing? Valves adjusted correctly? Brakes not dragging?
Thanks for jarring my head, I'll check the valves and do a comp and fuel pressure test tomorrow. Need to buy a timing light to test timing soon as well
