Clutch Issue
    Clutch Issue
    Ok, so just did a clutch on the coupe, but when i put her into gear, nothing happens. Even if i let off the clutch in gear, she idles like shes still in neutral. Could this be a bad slave? Fluid level was low when we checked it, filled it and still nothing.
    Also, the odometer moves slowly on its own and the speedometer sits at 10 MPH at idle and when you rev her up, speed needle goes up too.
    Any ideas? again
    Edit: so i think the odometer issue is stemming from the speedo needle sitting at 10 MPH and would probably explain why she doesnt stall in gear with clutch out, but doesnt explain why it's happening.
    Sounds like you put the disc on backwards
      He said he made sure the flywheel side was facing the flywheel (disc had a stamp indicating).
        Are the pressure plate bolts tight?
        MRT: 1993 Honda Accord SE Coupe (Lola)
          Should be tightened down.
            Did you bleed the system, or just fill it? The clutch hydraulic system is a closed system. The fluid should never go anywhere. If the fluid was low, you have a leak. You have air in your system. Your pedal is doing nothing.
            However, that should result in the clutch always being engaged.
            Are your cables connected and intact?
              It was filled, but not bled yet. When i added fluid, it got a little stiffer, but not much. As far as cables, not 100% sure.
              Also, would fluid cause issues with pedal adjustment?
                ya, you need to bleed the system. But with that said Deev is right, if you're clutch is doing nothing it would always be engaged, even in gear or changing gears.
                Is your slave cylinder moving when you push the pedal?
                  Yes, it moves
                  The passenger side axle isnt fully seated... oops fixing now
                    RESOLVED: with the axle out, the gearbox was spinning without 3800 lbs of resistance and would drop to 0 MPH with clutch in. It was in, but not completely flush. Bled and filled the system and so far, so good
