My grandmothers 93 speedo don't work so replaced the sensor on the trans, still no worky. Is there a part on the cluster that can be repaired?
Bad cluster/speedo?
Does the odometer still work? The speedo and odometer work off the same signal from the VSS. If the odometer works, then the signal is getting to the gauge cluster and yes, the speedometer can be replaced. There might be issues with corrosion on the printed circuit board in the gauge cluster.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by CB7Xhris View PostThe odometer and trip don't work ether.
If just trying to verify the VSS, there might be an easier place to break into the wiring harness under the hood - I don't have my manual handy while typing this.
Do you have a wiring diagram?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
